AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How can I supress co-ordinates in isometric? only Elevation will be there.
6 REPLIES 6
kumarswapan64
1015 Views, 6 Replies
How can I bring the complete Pipe Tag in Isometric drawing, now it is coming "Line No.-Pipe size-Spec".
I want it should come like "Size - Spec. - Service - Line No."
Swapan Kumar
6 REPLIES 6
Dan.Scales
in reply to: kumarswapan64
Try this:
  1. Turn off/uncheck the Append Coordinates and Elevation box under project setup for each End Connection Annotation type.
  2. Open the Isoconfig.xml, search for “ElevationScheme – Elevation” or “ElevationScheme – ElevationExtended” and set the Enable value to “true”, use either 1 or 2 depending on how you want your elevation to be displayed.
Hope this helps,
Dan
Dan Scales
kumarswapan64
in reply to: Dan.Scales
Thanks Dan
supress of co-ordinates its working as per your advise.
what about the other query?
"How can I bring the complete Pipe Tag in Isometric drawing, now it is coming "Line No.-Pipe size-Spec".
Swapan Kumar
Dan.Scales
This can also be configured in the isoconfig.xml. This time by editing the LineNumberScheme to this:
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{1}-{0}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC Service" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}-{2}" LineFormat="{0}" />
One thing to note is that if the Service has not been assigned then no isometric line number will be written to the isometric.
This is a link to the Help file section on this:
http://docs.autodesk.com/PLNT3D/2014/ENU/filesPLNT3D/GUID-B60BFFD0-1700-4B68-9A31-6BF9A9968ECC.htm
You may also find this useful:
http://www.pdoteam.com/2012/05/customizing-line-display-in-plant-3d-isometrics/
Hope this helps.
Dan
Dan Scales
kumarswapan64
As per the Following Link
I am able to bring the Service in my Pipie tag but,
1.  Size is not coming.
2. IN SOME PIPE MODEL SOMETIMES it is coming like "--FW-117", IN ANOTHE PIPE LINE it is coming "-MSBK08.50-FW-117".
3. BUT BOTH THE CASES SIZE IS NOT COMING IF "LINE DISPLAY"
4. IN DATA MANGER "LINE DISPLAY" COLUMN IS NOT COMING.
PLEASE HELP ME OUT.
Swapan Kumar
dave.wolfe
Did you set the nominal size/spec in the line group properties?
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
kumarswapan64
in reply to: dave.wolfe
Sorry !
Still proble is there........
Somteimes spec is coming but in all cases Size not coming.
Swapan Kumar
”Boost
