Hello
How can I add a support to a valve, so that I can see the support in an isometric?
G
Solved by Bernd.Gerstenberger. Go to Solution.
Is the support part of the valve or another itemised part?
If its a separate part, you can place a pipe support on a valve, as you would normally on a pipe.
Hello
I've tried some options:
1. I create an own support in a catalog and include it into the spec and place it to the valve: I get an open end (waterdrop) and two isometrics, one with the support only
2. I include an existing support (Alignment guide) into the spec and place it to the valve: same behavior like 1.
3. I use '_PlantPipeSupportAdd' in the model and place also the 'Alignment guide': everything works fine
What shall I do? I need own supports.
best regards
Hi Guido,
You have to do this on a different way because supports are special and have his own spec. Try this:
Please, inform me, if I could help you here.
Regards
Bernd
Hi Bernd,
that's the solution! Thanks.
(I've tried it with an own catalog also and it works too)
Guido
