AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
horto creation with autocad structural detailling object
11 REPLIES 11
Message 1 of 12
patpat78
750 Views, 11 Replies
hello
i realise a drawing with ASD i can watch it in plant 3d but when i generate an ortho drawing the steel structure does not comming ...
any idea? it's a very big problem for me...
thank's
11 REPLIES 11
Message 2 of 12
ybogdanov
in reply to: patpat78
Do you have object enabler of ASD installed? The ASD objects are 3D forms of AutoCAD, that's why they have to generated in sections without problems. In my projects it work correctly.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Message 3 of 12
patpat78
yes but there is the error message..
c:\program files\autodesk\autocad plant 3d 2012 - english\asdload.arx cannot
find a dll or other file that it needs.
 how can i solve this issue?
Message 4 of 12
ybogdanov
I prove to copy dwg of ASD to Plant3D project with the command of Plant from Project Manager. But the Plant say the same like in your case: don't find this arx file. And open window of "Fatal Error" and close program. I comprove, and in the folder this file is... I hope that problem is the bad installation of program.
 But my solution is :
 - Create new dwg file in the Project Manager of Plant3D.
- Open this file with ASD and the program ask you that if you want to convert this file in the ASD steel file, acept it.
- Create the structure (or in your case copy the structure from other exist file).
- Close it in ASD, and prove open with the Plant3D from Project Manager. In my case this solution work.
Yury Bogdanov
Barcelona (Spain)
Message 5 of 12
ybogdanov
in reply to: ybogdanov
For the people of Autodesk:
 This is the FATAL ERROR of Plant3D when I intent to copy the ASD file to Plant3D project from Project Manager. Is posible to resolve?
Yury Bogdanov
Barcelona (Spain)
Message 6 of 12
patpat78
hello i try to copy but it doesn't work......... any other idea
Message 7 of 12
ybogdanov
Do you have the ASD 3D model in the Plant3D project ? Can you visualizated it in Plant3D?
Yury Bogdanov
Barcelona (Spain)
Message 8 of 12
patpat78
yes i can vizualize asd model but snap doesn'works ..
when i try to creat ortho view i can see the asd model in the ortho box creation but i can see the error message and then when i creat the orto view there is nothing in the viewport and the same error..
Message 9 of 12
patpat78
hello
finaly i can copy asd to plant3d files.. i need to delete all drawing and number on asd first then the copy paste was ok..
but now as you can see on the picture this is the ortho result... very bad drawing
any idea for this other problem ?
Message 10 of 12
Arun_Kumar_K
Refering the above, enclosed herewith the generated Ortho in Plant 3d of the building modelled in ASD formwork.
The ortho generated can be rated as "Very Bad" in Plant 3dd, which cannot be used for delivery of drawings to our site.
What s the solution Autodesk have for this?
Arun Kumar
Message 11 of 12
Arun_Kumar_K
in reply to: Arun_Kumar_K
Awaiting for answer from Autodesk for the past 2 days.
Message 12 of 12
ASD Object Enabler, possible solution for the ASDLoad.arx warning:
1.       Close drawings and exit Plant 3D 2013
2.       Copy RBCTAppCore.dll file from "c:\Program Files\Autodesk\AutoCAD 2013\ASD" to the ‘main’ folder of Plant 3D which is " C:\Program Files\Autodesk\AutoCAD Plant 3D 2013 – English”
3.       Launch Plant 3D, warning about ASDLoax.arx should no longer appear
”Boost
