Hey,
I found a problem with Horizontal Cylinder Actuator.
Regardless of the value that is inserted a colossal size appears.
Check annex image.
Why there is not an option to insert the diameter of the horizontal cylinder?
Att.
Gabriel Nogueira.
I just discovered the same error. Has anyone come up with a solution to why this is happening? Does Autodesk know about this so they can fix it? I'm working in 13 so maybe it's already been fixed for 14....
Same issue here... Also on some valves/instruments when you choose that its no longer editable after the fact! That doesn't occur with other actuators.
They should let you choose all the major dimensions on an actuator
I am also getting this issue in 2014. Would really love to be able to specify more dimensions for actuators, this tool is quite limited compare to the equipement and valve builder tools.
This is on the same thread, but is on another actuator from the catalogue builder - I had previously used & had the same problems as you. The ones that i have tried have failed for some reason - a lot of time has been wasted. They all seam to ignor the catalogue dimensions when the item is placed within the model - I have tried metric & imperial.
Autocad should start looking at these posts so we can get solutions quicker.
Regards
Gary
