AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
hidden lines not working properly when I use the ortho cube cutting method
2 REPLIES 2
532 Views, 2 Replies
I cut a couple Ortho views - one plan view and the other an elevation view of the same area.  I did the Plant 3D ortho cube and everything was going along great until I tried to plot it.  I made sure the viewport was "hidden" but it doesn't come out hidden.  I tried every other "hidden" type in there as well, like the legacy hidden and the 3d hidden.  Nothing works.  So, I went ahead and xref'd in a piping model and cut a view in the old traditional way and it plotted just fine.  Please help.  I would like to use the ortho cube.  It's a great tool, but if I can't plot with it then why use it?
2 REPLIES 2
phwatso
When you created the view (in the orthocube mode) did you change the view to hidden on the tool ribbon pulldown menu?
in reply to: phwatso
Thank you. I was following a video to learn how to do this and of course it didn't cover that part.
”Boost
