AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Hidden 3D-Solids
4 REPLIES 4
kudryavcevrm
635 Views, 4 Replies
Hidden 3D-Solids
Hi Autodesk and users!
We met some stranges with P3D 2013. When we creating difficult equipment, we always explode p3D objects (pipes, elbows, valves, etc..) and got 3D-solids; after that we combine this solids into new equipment creating.
So, now we got strange errors in this way: some 3D-solids in 3D models are become hidden.
Please, look at my 2014 project attached.
At picture attached "After_CTRL_A_Pressed.jpg"  you can see  this hidden 3D-solids grips after "Select all" command. And you can to grip edit (for example,stretch) and this solid edited becomes visible again! ( see "After_grip_edit.jpg" file)
Please help me to understand why we got such hidden 3d-solids and how to correct them to become a visible again!
Thanks in advance!!
4 REPLIES 4
kudryavcevrm
in reply to: kudryavcevrm
kudryavcevrm
here's a project
You may have a corrupt drawing file. I was able to start a new drawing in the Plant 3D Drawing files and then pasted your drawing into the new drawing. Once it was pasted into the new drawing it appeared like it should normally appear.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Hello, Quentin!
Thank you, thank you very much. This works! I'm almost satisfied, but I just want to understand why I got this corruption.
We got such kind of corruption for a 2 different drawings (equipment templates) at 2 different workstations in Plant 3D 2013 SP2.
Symptoms :
1) Strange behaviour of such 3D-solids : they  blink (twinkle) or hides when I increase (+) zoom - it is something like the opposite to adaptive degradation . After that I had turned on hardware acceleration, after that I had closed drawing, after that I had closed plant 3D.
2) After Plant 3D restart and after re-open drawing I got missing 3D-solids like in attachement.
May be you sometimes met the bug like described above?
”Boost
