AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Help Question - Adding New raw to properties...
5 REPLIES 5
milic.srdjan
546 Views, 5 Replies
Halo to all Smiley Happy
Is it possible to add raw with SERVICE data to this part, exactly to process line ..
Look at picture
I wish to have possibility  to add SERVICE (e.q air, or process, or water) to process line in properties dialog
Srdjan Milic
5 REPLIES 5
RSFAdsk
in reply to: milic.srdjan
Yes you can add a property to in individual part in project setup.  For line properties you might prefer to add them to the  P3D Line Group.  Components that are part of the line can acquire from the group. In datamanager if you order by area and select Pipe Lines in the tree you can modify line properties (select the line number in the table, not the tree).
If I understand correctly, service is already setup for you there (attached).
Richard Frank
Autodesk Knowledge Network
Autodesk, Inc.
RSFAdsk
Looking at this a bit more I may have missed a main part of the quesiton.  Adding a property to the P3D Line Group allows it to display in the Process Line panel of the properties palette.  But for the Service property that already exists, I can only get it to display there if I create a new property.
Richard Frank
Autodesk, Inc.
milic.srdjan
in reply to: RSFAdsk
Thank You on so quick response..
but at frst...
1. Why I can not display existing SERVICE row in Properties for Process line.. It will be much easyer to use this existing raw
and...
How, for God's sake,  Smiley Happy You make some Property with brackets....
Look at picture
I get error that is not possible to add Property Name with non usual characters...
and to make more clearly my Question from beginning, I do not have any P&D drawing in project , but I wish to make possible for Designers to choose SERVICE for process lines  and some another Properties, because I wish to have Tag Format for Line number something like
NominalDiameter "-Unit-Service Number-Line Number-Nominal Spec-InsulationType
e.g. 10"-65-P-23690-AA23B-PP
Srdjan Milic
You have a space in the property name.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
RSFAdsk
The actual Property name has strict requirements (no special characters or space).  But you can set [special] characters in the Display name.
In the Palette, Pipe Run Components do have a Service property, which causes the value to display in the Properties Palette under General.
Regarding tag format, you can sel the tag format.
Even if you do not use P&ID, it might be good to review the documentation and videos regarding tagging and annotation.  The tagging concepts are similar, but in P&ID the results are much easier to see.
Richard Frank
Autodesk, Inc.
”Boost
