AutoCAD Plant 3D General DIscussion
Distinguished Contributor
20 Kudos
Post 1 of 4
Help me to create a New and Complex Pipe Spec
509 Views, 3 Replies
12-14-2012 09:52 AM
I'm working with Glass-Lined Steel Systems, the pipe and fittings are completely different of the usual carbon steel. All connections are made by Flanges (Split Flanges) and stub-end is fabricated on the pipe and fittings, the dimensions are not standard. There are pre-standard pipe lengths etc etc.
That all is driving me to create a new Pipe Spec on Plant 3D.
Is there some material to help me with this job?
Check some pictures of the fittings.
Our Mainly reference is Pfaudler, and De Dietrich.
Att.
Gabriel Nogueira
Valued Mentor
18 Kudos
Post 2 of 4
Re: Help me to create a New and Complex Pipe Spec
12-14-2012 10:19 AM in reply to: Gabriel.N
start modeling up the pipe fittings, each type for each size ( yes takes a while )  Then create blocks with each one.  Once they are blocks type <plantpartconvert> then add in your connections.
once you have all that done, you need to break out the spec editor.
Open up any catalog - SAVE IT UNDER A DIFFERENT NAME - then delete everything in it - now you have a blank catalog to add your parts in it.
<Create New Component>
under <graphics>
tag <Custome - AutoCAD DWF Block based graphics>
fill in all the blanks for your part.
Make sure you have the <long description (size)> labled properly with what it is and the size.
that's the basics.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
20 Kudos
Post 3 of 4
12-14-2012 10:32 AM in reply to: JohnHolder
Thank you, JohnHolder,
That helps a lot.
If anyone has more information or some documents I would greatly appreciate it.
Valued Mentor
18 Kudos
Post 4 of 4
12-14-2012 10:47 AM in reply to: Gabriel.N
ha have had to create a lot of custom blocks.  I just can't find the documentation I used to figure it out. Or I would have linked it.
Master Yoda.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
