AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Message 1 of 11
mandy.chen
1323 Views, 10 Replies
HDPE
I am looking for HDPE pipeline specs and catalogues. Does anyone know if there are any existing ones or do I need to create them from scratch?
10 REPLIES 10
Message 2 of 11
JohnHolder
in reply to: mandy.chen
most likely create them from scratch.. that is what I have to do aswell.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Message 3 of 11
mhamed.aissati
in reply to: JohnHolder
Message 4 of 11
JohnHolder
in reply to: mhamed.aissati
maybe I just can't find it.
There is nothing in there that is useable for HDPE in Canada.
Master Yoda.
Message 5 of 11
I'm looking for a good HDPE pipe catalogue as well. Are there any catalogues that I can just modify the parameters to suit what I need instead of having to make all the parts over again individually?
Message 6 of 11
I've been looking for a while.  I gave up and I am going to build one... like I had to do for sch 40 pvc and pvcu.
spears has one, but I still had to make a bunch of fittings since it is woefully incomplete.
Master Yoda.
Message 7 of 11
Venkatesan.A
You can create your own catalog's at ease with our "New Catalog Builder" in Plant 3D 2013.
Alternatively if you want to request a new content pack please check the below link .
http://autocad.autodesk.com/?nd=form__105
Do mention the specific standard/manufacturer you are looking for, if any.
Venkatesan.A
Support Specialist
Product Support
Message 8 of 11
JohnHolder
in reply to: Venkatesan.A
I still find it easier to model each fitting myself.  Each time I have attempted to use the catalog builder it has failed.
Master Yoda.
Message 9 of 11
JohnHolder
after much more trial and error I have it working much better.
Master Yoda.
Message 10 of 11
Venkatesan.A
Hi John,
Glad to hear that.
As you mentioned once you explore it, this tool is certainly handy.
Venkatesan.A
Support Specialist
Product Support
Message 11 of 11
Do any of you know if theres a way to create a hose fitting for HDPE? Almost like a fitting that can do all angles so I don't have to make a custom fitting every time for awkward bends/elbows.
”Boost
