Solved by JohnHolder. Go to Solution.
We changed the box to wireframe by editing the Ortho Temp.dwg file default view setting which is stored in C:\Users\****\AppData\Local\Autodesk\AutoCAD Plant 3D 2014\R19.1\enu\Template
Weird, I have no issues having HA turned on and looking at the viewcube. When I turn HA off, the viewcube is harder to make out which view I'm looking at as the colors of the sides are extremely dithered rather than a transparent colored cube.
I'm not seeing similar problems attaching images using IE. If you can, try PM'ing me the images, I'll see if I can get them attached.
With the OrthoCube on, try different visual styles. Some of them do seem to make the OrthoCube opaque. Is there at least one visual style that works for you in this case? Does 2D Wireframe work?
Another idea is to check your video card driver. Certified graphics drivers
(If this answers your question, please mark it as an Accepted Solution.)
Managed to get IE working from home.
Good ortho -- you can see the piping - is with HA off.
Bad ortho is -- you cannot see the piping - is with HA on.
2d Wireframe works, but gets really cluttered with complicated drawings - so it is a minor work around
edit - no clue why it has a bunch of dots... not like that in autocad.
