Suddenly my hardware acceleration is greyed out in Plant 3D 2015. I can't turn it on. When I open Autocad 2015 it is possible to turn hardware acceleration. It worked a week ago. So I uninstalled all updates in the past week.I tried to install the certified drivers by autodesk.
My graphicscard is the Nividia K3100m. What can I do to turn on hardware accelration?
That is not true. When we bought the laptop I checked if it was certified. According to this website it is: Autodesk certified. I tried to instal the drivers from Nvidia but without any result. I had to deinstall the complete design suite and reinstall. Hardware acceleration is now eneabled.
HI,
As this was posted in the Plant forum I searched for AutoCAD certified drivers rather than Revit ones which is the reason I didn't find it.
In any case it is good that you have solved the issue.
Dan
