AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
GUID code of nozzles
8 REPLIES 8
Message 1 of 9
halitomi
939 Views, 8 Replies
Hi!
I am almost finished with my first customizable equipment prepared in Plant 3D.
Everything seems fine expect the nozzles. There is a GUID code (which I have copied from a template) for the default nozzle type which seems to be some ASME standard now (for example: e6d66a3a-576a-5c72-81e2-da665af60ee8).
Full code of mine:
Spoiler
<?xml version="1.0" encoding="utf-8"?>
<EquipmentType
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
Name="AIRSLIDE"
Type="C"
SubType="V"
PartSubType="GeneralVessel"
GUID="{697b3cf5-b0c8-4956-ad0e-a67e92846992}"
PartType="Vessel">
<DisplayName>Airslide</DisplayName>
<PartProperties>
<PropertyInfo Name="PartSizeLongDesc" DefaultValue="Airslide" />
</PartProperties>
<Categories>
<CategoryInfo Name="AIRSLIDE">
<Parameters>
<ParameterInfo Name="L1" DefaultValue="1100" />
</Parameters>
</CategoryInfo>
<CategoryInfo Name="A-B-C-C1">
<Parameters>
<ParameterInfo Name="A" DefaultValue="500" />
<ParameterInfo Name="B" DefaultValue="300" />
<ParameterInfo Name="C" DefaultValue="40" />
<ParameterInfo Name="C1" DefaultValue="5" />
</Parameters>
</CategoryInfo>
<CategoryInfo Name="L4-DP-LP">
<Parameters>
<ParameterInfo Name="DP" DefaultValue="88.9" />
<ParameterInfo Name="LP" DefaultValue="350" />
<ParameterInfo Name="L4" DefaultValue="200" />
</Parameters>
</CategoryInfo>
<CategoryInfo Name="L2">
<Parameters>
<ParameterInfo Name="L2" DefaultValue="100" />
</Parameters>
</CategoryInfo>
</Categories>
<Nozzles>
<NozzleInfo Name="FLS" PortName="S1">
<DisplayName>C1</DisplayName>
<Tooltip />
<NozzleTypes>
<NozzleType PartType="Nozzle" PartSubType="StraightNozzle" EndType="FL" />
</NozzleTypes>
<PortProperties>
<PropertyInfo Name=".SizeRecordId" DefaultValue="8843ee89-350c-5728-bcd7-797616cb3d56" />
</PortProperties>
</NozzleInfo>
<NozzleInfo Name="FLP" PortName="S2">
<DisplayName>C2</DisplayName>
<Tooltip />
<NozzleTypes>
</NozzleTypes>
<PortProperties>
</PortProperties>
</NozzleInfo>
<NozzleInfo Name="FLS" PortName="S3">
<Tooltip />
<NozzleTypes>
<NozzleType PartType="Nozzle" PartSubType="StraightNozzle" EndType="PL" />
</NozzleTypes>
<PortProperties>
<PropertyInfo Name=".SizeRecordId" DefaultValue="e6d66a3a-576a-5c72-81e2-da665af60ee8" />
</PortProperties>
</NozzleInfo>
<NozzleInfo Name="FLS" PortName="S4">
<Tooltip />
<NozzleTypes>
</NozzleTypes>
<PortProperties>
#<PropertyInfo Name=".SizeRecordId" DefaultValue="4b77a031-115e-53ce-affc-6aa39b8177f1" />
</PortProperties>
</NozzleInfo>
</Nozzles>
</EquipmentType>
Is there a list from which I can choose the appropriate GUID? (I would need DIN standard flange, PN10/PN16)
8 REPLIES 8
Message 2 of 9
KenFauver
in reply to: halitomi
Just create a new one. This can be done buy clicking the following link. http://www.guidgenerator.com/online-guid-generator.aspx
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
Message 3 of 9
halitomi
Ah this is okay.
But how do you determine the default flange type? I do not want to change all the time from this standard to that one (these flanges for this equipment are basically all the time the same type and size).
Message 4 of 9
Arun_Kumar_K
I do like to do coding like this and bring customizable equipments in plant 3d. Please let me what basic software knowledge I should have to do coding for creating equipments.
Message 5 of 9
halitomi
in reply to: Arun_Kumar_K
I only have some basic programing knowledge, nothing special.
And used this doc:
http://bit.ly/1dIlA44
Plus lot of experimenting.
Message 6 of 9
halitomi
Is it possible to make the EquipmentType.xml something like this?
<NozzleInfo Name="First" PortName="S1">
<Tooltip />
<NozzleTypes>
<NozzleType PartType="Nozzle" Unit="mm" PartSubType="StraightNozzle" EndType="FL" PressureClass="16" Size="150"/>
</NozzleTypes>
<PortProperties>
<PropertyInfo Name=".SizeRecordId" DefaultValue="19a79688-0f97-4445-9818-ddf27a239aba" />
</PortProperties>
</NozzleInfo>
This would specify exactly the nozzle type/size/etc.
But this is not working as you can see on the attached picture.
Message 7 of 9
Arun_Kumar_K
Thanks Halitomi for provided material.
Message 8 of 9
dave.wolfe
I think the sizerecordid has to match a size from the nozzle catalog. Locate the nozzle you want in the catalog and you should be able to use its sizerecordid I think.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 9 of 9
halitomi
Thank you for the idea!
By default you can not see the GUIDs of the nozzles in the Spec Editor. But if you export the nozzle catalgue to excel you can see them.
And also you have to give a new GUID to the equipment to make Plant recognise that the nozzle ID was changed.
”Boost
