AutoCAD Plant 3D General DIscussion
Active Contributor
3 Kudos
Post 1 of 8
Gridlines disappear when create an Ortho
853 Views, 7 Replies
11-07-2012 11:26 PM
I have te following issue: I create an orto of two pumps. I choose a grid model of the plant to attach. Because the grid is too big I adjust it to fit the pumps and some gridlines. I click create and my horizontal lines disappear. It looks like if a line fits the viewport it is displayed and if it is "cut" or should be cut it disappears. See image below. The first viewport shows the cropped situation and the lower viewport shows the complete model with gridlines. How to solve this problem?
This issue is solved in the 2014 release.
Product Support
35 Kudos
Post 2 of 8
Re: Gridlines disappear when create an Ortho
11-13-2012 07:41 AM in reply to: snijdam
I have reproduced this issue and will log it with our development team.
For now you will either need to ensure that the AutoCAD lines fall within the ortho view area.
Dan
Dan Scales
3 Kudos
Post 3 of 8
06-13-2013 03:21 PM in reply to: Dan.Scales
Has this been resolved in 2014?  We are using 2013 and have the same issue.
Active Contributor
3 Kudos
Post 4 of 8
06-14-2013 12:52 AM in reply to: snijdam
Distinguished Contributor
53 Kudos
Post 5 of 8
06-15-2013 10:08 AM in reply to: snijdam
I checked, the issue is not solved, only the lines what ever we draw is getting displayed in ortho. But the grid letters are not displaying.
53 Kudos
Post 6 of 8
06-15-2013 10:25 AM in reply to: Arun_Kumar_K
Untitled.pngIt comes, you have to use lines and line text.
New Member
0 Kudos
Post 7 of 8
07-23-2013 06:18 AM in reply to: Arun_Kumar_K
Hi can you explain how you do that, because I try and text is still missing when I create the Ortho views.
53 Kudos
Post 8 of 8
07-23-2013 09:27 AM in reply to: jkulig
Explode the Grid line text using Text explode command, then you will get it.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
