AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Grayloc fittings
1 REPLY 1
1622 Views, 1 Reply
Grayloc fittings
Has anyone modified plant3d to use Grayloc fittings?  If so, what is required?
1 REPLY 1
bogdanov.y
You can use LAP joint connection in this case. And in the description of LAP Flange change to description which you need.
 It's posible to use couple conection. In this case to find this type of conection is necessary use Custom Hold Catalog in the COMON folder. It is the only place where I find this kind of connection.
”Boost
