Halo to all,
I have several questions, and I think that experience of users can help,
and improve my PC ๐
Does certified or recommended graphic card is really important for Plant 3D modeling ?
P3D Users, did You really see and feel improvements when You start using certified graphic cards ?
Can You post, type of graphic card (GC) when You answer to question above ๐ ?
Are certified GCs are better then gaming cards for P3D, or You really need GCs that have only good support for OpenGL ?
Minimum memory on GC to have pleasant environment to work with large models ?
ATI FireGL or Nvidia Quadro ? (Please not make flames here, only inportant infos) I thought that NVidia have better OpenGL, but now I think that they are the same ๐
OK, I know, many questions, but, but...
I have GeForce 9500 GT and many many problems, specially when I use hardware acceleration. I I had degraded settings and problems still exist.
Srdjan
to be honest, I don't know. I use a Quadro FX1800, and either using the latest Nvidia drivers ( non certified ) or Autocad Certified drivers, I have seen no noticable difference.
With hardware acceleration, I have had nothing but issues using it. For me it is always off.
I just stick with using certified drivers.
With regards to gaming cards and professional cards, I cannot say one way or the other since I havn't really looked into it myself.
Given your litany of problems, I suspect you are very much an "edge case".
Quadro isn't so important any more, but I think there does need to be some management of expectations. Replacing a $1000 video card with a $5000 will not turn Plant3D into Navisworks or Inventor. Doing that with a barrel-scraping i3 with 6 GB RAM will only make a difference to your wallet. The important factors between gaming and Quadro cards are the other software being run ie. ReCap, CloudWorx, or other OpenGL-based software. Software which has a high dependency on OpenGL will require one of the workstation-type cards.
As always, when in doubt start looking at specifications. Software will list the requirements and hardware will list the capabilities. Ensure the latter meets or exceeds the former.
