AutoCAD Plant 3D General DIscussion
Valued Contributor
0 Kudos
Post 1 of 11
GF+ PE Pipe and fittings
1253 Views, 10 Replies
03-14-2012 10:31 AM
Hello
I  work in Autocad Plant 3D 2012 and I need to use GF+  PE Pipe and Fittings catalogue to create specs. Does anyone has faced this problem as me before.
Best wishes...
Gökhan Kaya
Altar Teknoloji
App Engineer
Valued Mentor
18 Kudos
Post 2 of 11
Re: GF+ PE Pipe and fittings
03-14-2012 04:16 PM in reply to: Altar_Kgokhan
Not sure about other people.. but I found most of the specs are missing too much to be useful.
so I made my own specs after modeling all the fittings needed.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Valued Contributor
5 Kudos
Post 3 of 11
03-15-2012 01:06 AM in reply to: JohnHolder
you can download complet gf catalog
http://autocad.autodesk.com/?nd=plant_content_packs
in europe section
Employee
5 Kudos
Post 4 of 11
03-15-2012 03:18 AM in reply to: Altar_Kgokhan
Autodesk Plant content team seeking your comment on the +GF+ content pack. Please read the readme file before downloading the content pack. Please let us know which materials of GF content do you use in your project?
http://autocad.autodesk.com/?autodownload=../secure/protected/Georg-Fischer-PVC-CPVC-Sch40-PVC-Sch80...
http://autocad.autodesk.com/ama/orig/plant/README__Georg_Fischer_PVC_CPVC_Sch40_PVC__Sch80_CPVC_Cont...
http://autocad.autodesk.com/?autodownload=../secure/protected/Georg-Fischer-PVC-C-PVC-U-ABS-Content-...
http://autocad.autodesk.com/ama/orig/plant/README_-_Georg_Fischer_PVC-C_PVC-U__ABS_Content_Pack.pdf
Looking forward to hearing from you.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
New Member
0 Kudos
Post 5 of 11
03-16-2012 12:55 PM in reply to: rajsekarpillai
Do you have any plans to create GF + PE catalogue? This one is missing.
Thank you
Bılent
Employee
5 Kudos
Post 6 of 11
03-16-2012 07:47 PM in reply to: Altar_Kgokhan
We are working on the priorities. Please vote your priority content pack requirement through Request Content Pack form.
http://autocad.autodesk.com/?nd=form__105
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Valued Contributor
5 Kudos
Post 7 of 11
03-21-2012 03:47 AM in reply to: rajsekarpillai
i think in the GF catalog PVC there are some problemes
for diameter 63 for exemple when we generate iso or in the line name it says "63mm" not only "63" it's a big probleme for us because we cant use the spec wtih mm at the end of diameter... any idea ?
Employee
5 Kudos
Post 8 of 11
03-22-2012 03:10 AM in reply to: Altar_Kgokhan
Please update the "NominalDiameterMap.csv" in your AutoCAD Plant3D root directory. To do that, Please download the attached file and replace existing file under "C:\Program Files\Autodesk\AutoCAD Plant 3D 2012 - English\".
Note:  It is a good practice to back up the existing file before replacing it with the updated
version.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Valued Contributor
5 Kudos
Post 9 of 11
03-22-2012 03:25 AM in reply to: rajsekarpillai
it works thank's
Valued Contributor
5 Kudos
Post 10 of 11
03-29-2012 06:38 AM in reply to: patpat78
Hello
other problem the csv file works fine but how it works with the nozle or steel valve
for exemple we have GF pipe and flange in 110mm but we use socle buterfly valve in nd100 in the reality it works but autocad doesn't want to combine these component ..
any idea ?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
