AutoCAD Plant 3D General DIscussion
Active Member
MAD1975
Message 1 of 18 (27,432 Views)
Getting Fatal Error : Unhandled Access Violation Reading
27432 Views, 17 Replies
08-06-2012 07:00 AM
Reading 0x0000 Exception at f50cd74eh on startup of Plant 3d 2013.
Tried the Repair option. It didn't work.
Reinstalled Plant 3d 2013 after uninstalling everything 2013 related but it didn't work.
The program crashes at startup even if I start only the program and not a project.
Windows / vid card etc are all up to date.
Plant 3d 2012 is still working.
Is there something I should know to fix this ?
I had the same problem, just delete the cache files in the following directroy back to a day your system last worked.
C:\Users\xxxxxx\AppData\Local\Autodesk\AutoCAD Plant 3D 2013 - English\R19.0\enu\GraphicsCache
Member
mtchad
Message 2 of 18 (27,420 Views)
Re: Getting Fatal Error : Unhandled Access Violation Reading
08-06-2012 08:56 AM in reply to: MAD1975
Active Member
MAD1975
Message 3 of 18 (27,421 Views)
08-06-2012 09:16 AM in reply to: mtchad
Thank you, this worked perfectly.
You're a genius ! :smileyhappy:
New Member
MARKPERKINSON8722
Message 4 of 18 (27,305 Views)
08-13-2012 07:16 PM in reply to: mtchad
Yes, you ARE a genius.  Thanks for this post.  Having a the same problem exactly w/ Autocad Architecture 2013.  Tried the same repair and reinstall efforts to no avail.  This fix did the trick straight away.  Not even a reboot needed.  Much gratitude.  /m
New Member
wglavin
Message 5 of 18 (27,255 Views)
08-17-2012 06:35 PM in reply to: MARKPERKINSON8722
I have the same problem but it happened about 3 months ago so I don't know how many cache files to delete to get rid of this Error.  Can I cause more harm if I delete too many cache files?  I really would like to use all of the Plant 3D 2013 (student version) features once again ASAP.  -thanks
Active Member
MAD1975
Message 6 of 18 (27,198 Views)
08-21-2012 11:11 AM in reply to: wglavin
You could just move the file to another folder instead of deleting them. Put them back in if needed.
New Member
wglavin
Message 7 of 18 (27,113 Views)
08-31-2012 03:06 AM in reply to: MAD1975
unfortunatly this did not work and I'm still receiving the fatal error?
Member
aman.issar1
Message 8 of 18 (26,255 Views)
10-26-2012 01:54 PM in reply to: MAD1975
i followed the steps u mentioned
my graphicsCache folder was empty though
is there any other way that this issue can be rectified ?
i would really appreciate if you could help me
Member
aman.issar1
Message 9 of 18 (26,255 Views)
10-26-2012 01:55 PM in reply to: MAD1975
Valued Mentor
Rich.O.3d
Message 10 of 18 (26,048 Views)
10-31-2012 05:49 PM in reply to: aman.issar1
try deleting the following from the registry (NOTE: MAKE BACKUP OF REGISTRY BEFORE YOU DO ANYTHING)
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B017:409
then when you fire up plant again, this part should rebuild itself
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
