Im trying to create a vertical filter, i put in the neccessary dimensions into the dialog box but get the following error...
Command: _PLANTEQUIPMENTCREATE
Command: zipimport.ZipImportError: can't find module 'varmain'
Choose insertion point:
Rotate or [Plane]:
Geometry can not be generated with the given parameters.
Had you checked your Drawing units?
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
I just repeated your process using PLANTEQUIPMENTCREATE and I did not get the issue you are having.
Try to start a brand new Plant 3D project and then try PLANTEQUIPMENTCREATE. Does the issue still occur?
If the issue still occurs you might want to go to Uninstall Plant 3D and do a Repair.
If the Repair does not work, go back to Uninstall Plant 3D and do a Reinstall.
Quentin Contreras
Technical Support Specialist
Started a new project and the same thing happened.
Done a 'Repair' same problem
Done a 'Reinstall' same problem
