AutoCAD Plant 3D Forum
Geometry can not be generated with the given parameters
4 REPLIES 4
lewisparkins
481 Views, 4 Replies
Im trying to create a vertical filter, i put in the neccessary dimensions into the dialog box but get the following error...
Command: _PLANTEQUIPMENTCREATE
Command: zipimport.ZipImportError: can't find module 'varmain'
Choose insertion point:
Rotate or [Plane]:
Geometry can not be generated with the given parameters.
4 REPLIES 4
patpat79
in reply to: lewisparkins
Had you checked your Drawing units?
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
lewisparkins
in reply to: patpat79
yep, units are in mm, as they are supposed to be.
I just repeated your process using PLANTEQUIPMENTCREATE and I did not get the issue you are having.
Try to start a brand new Plant 3D project and then try PLANTEQUIPMENTCREATE. Does the issue still occur?
If the issue still occurs you might want to go to Uninstall Plant 3D and do a Repair.
If the Repair does not work, go back to Uninstall Plant 3D and do a Reinstall.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Started a new project and the same thing happened.
Done a 'Repair' same problem
Done a 'Reinstall' same problem
”Boost
