AutoCAD Plant 3D Forum
Generating Specs
1 REPLY 1
283 Views, 1 Reply
Generating Specs
I'm generating a spec and everything is going ok, but I'm not being able to access it in the AutoCad Plant 3D. Is there some specific folder I have to save the spec file in? Is there any "import spec" command I should click once I open my project?
Eduardo Vertis.
1 REPLY 1
TRdesigner82
The specs have to be located in the "Spec Sheets" folder under you Plant 3D project. See the attachments for clarity...
”Boost
