AutoCAD Plant 3D General DIscussion
gschimmi
Message 1 of 6 (636 Views)
gasket info in the model
636 Views, 5 Replies
07-13-2012 03:30 AM
Hello
when I press ctrl and click a flange connection I can get info for used bolt set but not for the gasket. Where can I see the used Gasket?
Guido
Plant3D 2014 German
WIN7
Simply ctrl-click on the gasket.
You may need to change the visual style to see the gasket; you may also find it useful to enable selection preview in your Options.
Andy
Valued Contributor
andy.davis
Message 2 of 6 (632 Views)
Re: gasket info in the model
07-13-2012 05:11 AM in reply to: gschimmi
Andy
Valued Contributor
vannmannen
Message 3 of 6 (549 Views)
04-03-2013 07:09 PM in reply to: gschimmi
Following up this one: No, we can not change gasket, only bolts when ctr-right click on the gasket. See attachment
Employee
TomislavGolubovic
Message 4 of 6 (542 Views)
04-03-2013 09:29 PM in reply to: gschimmi
Change to Wireframe view and select the gasket
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Active Member
ugurbalbay
Message 5 of 6 (418 Views)
07-15-2013 06:05 AM in reply to: gschimmi
Yes we can see the gasket when we go into the wireframe but we can not change the gasket!!!!!
How we can change gasket in the programme if we have more than one gasket in the spec.
Employee
TomislavGolubovic
Message 6 of 6 (400 Views)
07-15-2013 05:13 PM in reply to: ugurbalbay
The Gaskets and Bolts are inserted as a Connector, so they are grouped. To change either one, you press the CTRL key and select the gasket. Then you can change the properties or substitute it.
Tomislav Golubovic
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
