Hello
when I press ctrl and click a flange connection I can get info for used bolt set but not for the gasket. Where can I see the used Gasket?
Guido
Solved by AndyDavisCadline. Go to Solution.
Simply ctrl-click on the gasket.
You may need to change the visual style to see the gasket; you may also find it useful to enable selection preview in your Options.
Andy
Following up this one: No, we can not change gasket, only bolts when ctr-right click on the gasket. See attachment
Change to Wireframe view and select the gasket
The Gaskets and Bolts are inserted as a Connector, so they are grouped. To change either one, you press the CTRL key and select the gasket. Then you can change the properties or substitute it.
