AutoCAD Plant 3D Forum
gasket info in the model
5 REPLIES 5
GSC_HAYA
2656 Views, 5 Replies
Hello
when I press ctrl and click a flange connection I can get info for used bolt set but not for the gasket. Where can I see the used Gasket?
Guido
Plant3D 2022 German
WIN10 Pro
5 REPLIES 5
AndyDavisCadline
in reply to: GSC_HAYA
Simply ctrl-click on the gasket.
You may need to change the visual style to see the gasket; you may also find it useful to enable selection preview in your Options.
Andy
Andy Davis
Industry Specialist
Cadline Ltd.
vannmannen
Following up this one: No, we can not change gasket, only bolts when ctr-right click on the gasket. See attachment
Change to Wireframe view and select the gasket
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
ugurbalbay
Yes we can see the gasket when we go into the wireframe but we can not change the gasket!!!!!
How we can change gasket in the programme if we have more than one gasket in the spec.
The Gaskets and Bolts are inserted as a Connector, so they are grouped. To change either one, you press the CTRL key and select the gasket. Then you can change the properties or substitute it.
Tomislav Golubovic
Autodesk, Inc.
”Boost
