Hello
While using an specification wich includes 8" Slip On flanges, i'm trying to place a 8" flanged ball valve next to an elbow.
Is there any place where i can set or fix the gap between the weld of the elbow and the exterior weld of the S.O. flange? I don't want to weld the elbow with the flange (like it's shown in the attached file)
thank you
You have the option to set weld gaps in the Project Setup:
http://docs.autodesk.com/PLNT3D/2014/ENU/filesPLNT3D/GUID-1106BB51-54B6-4641-9F95-818B6E29F433.htm
Dan
If I understand your question right, it sounds like you want a small piece of pipe betwen the elbow and flange. To do that, you will need to route a small piece of pipe and then add the SO flange to the pipe, not the elbow. Then you can use the grips to slide the flange to the place you want.
If you draw the elbow and then place a short length of pipe on the elbow you can insert the slop on flange on the end of the pipe by holding the Ctrl button down when you place it on the pipe. Holding the Ctrl button allows you to toggle the side of the flange that is connecting.
In the screen shot you can see a 25mm length shown in green:
Is that the type result you want?
Dan
I tested it out and I see what you are saying. I was able to place a flange not attached to anything, route a 2" piece of pipe as measured from the face of the flange (using offset lines as a guide) and draging to the line using the plus sign. I then moved the flange and pipe and connected the node of the pipe to the node of the elbow.
I don't think there is a way to do that in a project setup.
Thank you everyone for your answers.
I've tried this solutions, but when i tried to move the flange (using control to change the grip point), i only can grip the "A" (end of flange) and "B" (inner weld) points (like shown in the attached file option1). I need the 50mm gap between "C" point and the elbow, but i don't know how to grip the flange from "C" point.
If i move the flange from the "B" grip point, i need to know the lenght of the flange to do what i want.
When i tried to put firstly the flange and after the pipe, i can't set the offset from point "c" (see attached file option2)
Thanks all you for your patience,
When you say you want a 50mm gap between point C and the elbow, do you mean that you need a 50mm length of pipe or an actual gap?
If you want 50mm of pipe then you need to draw the pipe section on the elbow and then place the flange onto the pipe.
Dan
I don't want a 50mm pipe, i need a pipe little longer.
I
The 50mm must be from weld to weld
I solved this question some time ago
The problem was with the engagement lenght in SO flange. The pipe starts routing includes this engangementh lenght. So, if i route a pipe of 50mm, there aren't 50mm between the flange and the elbow, it's little less becouse includes the engagent of flange
What i have done to control this i to make new spec, setting all engagemnts to 0 in socketweld accesories. Then, all pipes routed from socket counts since the outter weld, not the engagement.
The olnly problem is that the total meters of pipe results in a few mm less than required, but it's only a few
