AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
FRP - Fiber Glass Pipes (AMERON)
3 REPLIES 3
Gabriel.N
2074 Views, 3 Replies
I'm setting up a Spec using the catalog base from AMERON.
I'm probably doing something wrong, I insert into the spec Elbows and the Pipe SKTxPE, when I m routing the pipe always have a Male X Famale Connection, and it and should use Male x Male between to Elbows.
Check annex image.
Should I create a Pipe Male x Male?
3 REPLIES 3
Venkatesan.A
in reply to: Gabriel.N
Hi Gabriel,
If you dont want an integral pipe but instead a MaleXMale pipe yes you should add it to your spec and assign the pririority accordingly in the spec.
Note : You should check Ameron Catalog for such suitable male end frp pipes based on the joint type/series/pressure ratings.
Venkatesan.A
Support Specialist
Product Support
ronalrau
in reply to: Venkatesan.A
Dear AutoDesk Team,
I have problem as Gabriel, I can't insert flange to pipe. please help me solve proble.
 Thanks!
Venkatesan.A
in reply to: ronalrau
Please define the connection for FL-PPL under project setup, then it should connect.
Venkatesan.A
Support Specialist
Product Support
”Boost
