Im currently using Bentley Autoplant 2012. When im in paper space dimensioning a drawing, i'll be moving my dimesions and text around. Every now and then certain dimensions that use to move before will end up freezing the drawing if i try to move them. I cant even erase them, copy them, do any thing with them. I tried everything from restoring the drawing to checking for blocks or currupt data and found nothing. this project is past due so what i ended up doing was creating another drawing and copy the dimensions and text that did move around onto the other one. As i was fixing and placing the missing dimensions about 2 hours in it happened again. At first it happens to certain text and dimensions then over time all of them get like this. i cant do anything to the text or dimensions without it freezing up my drawing and having to close it. Any help or similar situations with a solution?
