AutoCAD Plant 3D Forum
Flow Arrow On Isometric 2012
10 REPLIES 10
Message 1 of 11
DJPiper
2227 Views, 10 Replies
There is a dimension appears on Flow arrow on Isometric. and if the line is insulated it also gives an Insulation break. is there a setting to turn this off?
10 REPLIES 10
Message 2 of 11
DJPiper
in reply to: DJPiper
guys, anyone? i havent figure out how to turn off this very special feature..
Message 3 of 11
Vicky.Wu
Turn off Insulation break annotation:
Go to IsoConfig.xml from project style folder. e.g. Project name\Isometric\Check_ANSI-B
Comment out selection below string or Delete it.
<PropertyBreakerScheme Name="InsulationLimit" AnnotationStyle="SpecBreak" Tag="Left Right" Alignment="FlatHorizontal" LeaderStyle="AlwaysNonArrowed" Filter="NotBoltOrWeld" Field="HasInsulation" DefaultAnnotationStyle="Standard" DefaultL-->eaderStyle="Always" WordWrapLimit="10" EnableMultiple="true" />
Btw, the issue regarding dimension for Flow arrow has been identified. Thanks for your reporting it.
Vicky
Autodesk Plant Solutions
Message 4 of 11
in reply to: Vicky.Wu
Hi Vicky,
Is your reply the answer to the flow arrow issue?
Thanks and regards
Message 5 of 11
Vicky.Wu
My above reply is to solve insulation annotation for flow arrow.
Remove dimension of flow arrow:
Go to isoconfig.xml file to modify, e.g. Project\Isometric\Check_A2\isoconfig.xml, add below red string.
<Filter Name="Fitting" Value="NOT (Type = 'Pipe' OR Type = 'Gasket' OR Type = 'REINFORCEMENT-PAD' OR Type = 'Flange' OR Type = 'Bolt' OR Type LIKE 'Valve*' OR Type = 'Olet' OR Type LIKE 'Instrument*' OR Type = 'Support' OR Type LIKE 'Elbow*' OR Type LIKE 'Cross*' OR Type = 'Weld' OR Type LIKE 'Tee*' OR Type LIKE 'Y-*' OR Type = 'FLOOR-SYMBOL' OR Type = 'FLOW-ARROW')" />
The issue has been fixed in our next release.
Thanks very much.
Vicky
Message 6 of 11
Dan.Scales
The issue where a dimesion is being placed for the flow arrow has been escalated to our development team so it is something that is under current investigation.
Dan
Dan Scales
Message 7 of 11
in reply to: Dan.Scales
Excuse me, is the placed-dimension issue already solved? Thanks in advance
Message 8 of 11
Vicky.Wu
Yes. We have already fixed  both above 2 issues in Plant 3D 2013. Thanks for your concern!
Vicky
Message 9 of 11
DJPiper
What about in 2012? is there a work around or Hot fix for this problem? we're currently using 2012 on our project. thanks!
Message 10 of 11
Ok...i have this flow arrow edit inplace.
I have a line that starts with a section of Rubber lined pipe from the pump then after FIT/DIT, the line continous an in a poly pipe spec.
on the poly section, flow arrows are aok
on the rubber lined section, the flow arrows are dimensioned!
Message 11 of 11
dpreezm
Hi I know this is a very old post, but this issue has not been resolved and I am working on version 2016?!?
-=StevieWonder=-
"Trust me, I'm a draftsman"
”Boost
