AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Flanged Piping Questions
25 REPLIES 25
Message 1 of 26
2220 Views, 25 Replies
I’m fairly new to Plant 3D (2012) and have a couple questions about flanged pipe:
1.) I can’t see a simple way to create a Flanged x Plain End pipe without using custom geometry.  This configuration doesn’t seem to be available when creating a new component.  I can create a pipe with a FL and PL port, but it graphically still shows two flanges in the model.  It seems like this should be a standard option…
2.) I’m looking for a way to connect two Flange x Flange pipes together without losing the flange connection in the middle.  An example would be a 20’ run of flanged pipe.  Say I can only get this pipe in a 17’-6” length.  I would need an intermediate joint and two spools of pipe to build this.  I’ve tried creating a flange component but it ends up changing one of the pipes to PLxPL, adds other un-needed parts and duplicates gaskets.  Is there a “break” command that forces an intermediate joint?
On a related note, I would love to see the addition (if it doesn’t already exist) of a Max Pipe length parameter in the catalog that would limit the length of pipe drawn.  When this limit is reached on a run, a flange connection would be added and a new pipe began.  This parameter should be per size since some manufactures have different maximum lengths based on nominal diameter.  Flanged US Pipe is a good example.
Thanks! -Jason
25 REPLIES 25
Message 2 of 26
So I think I found a work around to question #1.  I just chose a FLxFL pipe and changed the dimension parameters of one end to match the actual pipe.  I then identified Port 2 a PL.  This should work right?
Still need any help I can get for question #2.
Thx
Message 3 of 26
dave.wolfe
Yes, it will you can also set L2 to -2 and the flange won't be generated for port 2 (it uses the pipe size).
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 4 of 26
in reply to: dave.wolfe
Great tip, thanks!  I didn't notice the tool tip.  Any thoughts the other question?
Message 5 of 26
dave.wolfe
Yea, I forgot to read the second question.  You can set up a joint for flange connection.  For example, in my catalog, I used the LFL end type for lined flanges.  I get up a new joint connection that had bolts only (no gasket).  They when I drop in the valves, it shortens the flanged pipe appropriately.
I agree on the catalog editor deal and pipe runs.  The pipe lengths is a property of the part that can be ordered from the manufacturer AND it can be a standard set in the project.  We should be able to set the length the catalog and then override it as a project setting if we need to.
Please mark my post as the answer if it answers your question.  Marking answers helps other find solutions faster.  Thanks!
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 6 of 26
Dave, thanks for the quick response.  Sorry, but I'm not following you.  Are you creating a "dumby" valve to force the pipe to break.  Does the valve essentially represent the gasket?  How does this affect the Isos and bill of materials?  I'll have to do a little testing on this one...
I am a contractor so these sort of details are really important to us to be able to estimate and order material correctly.  Thanks,
-Jason
Message 7 of 26
dave.wolfe
No, if you set a Joint the pipe will recognize when an object with the matching end connections is placed and put in the appropriate connectors.
Setting up the joints is the only way to get the correct Bill of materials.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 8 of 26
I understand how joints work pretty well, but my problem is connecting two similar pipes and not losing the joint.  Say in real life, I have two 10' long FLxFL pipes bolted together... how do I model this without losing that joint?  See attachment...
Message 9 of 26
dave.wolfe
With the joint defined, select the pipe and use the PLANTWELDADD command.
On the note above about using -2, you have to put in the Pipe Od for D22, unless you just want engagement.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 10 of 26
Using that command I'm unable to select the pipe for some reason.  I'll keep researching in that direction...
Thanks for all your help, I appreciate it!
-Jason
Message 11 of 26
dave.wolfe
Right, you have to select the pipe first.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 12 of 26
Fantastic!  That's what I've been looking for.  Thanks!  Is there a way to move that weld after it's placed?  I don't see any grips on it...
Message 13 of 26
dave.wolfe
You can do a stretch command around the fittings...yea, remember AutoCAD?! Smiley Happy
Every now and then you can still use those commands.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 14 of 26
Ahh, the stretch command...   That works fairly well.  What I was hoping for was a way to select the joint (weld) and move it a specific distance from the other end of the pipe using dynamic input.  Basically setting the cut length of the pipe by moving the weld.  I can do it the other way though... select the pipe and move the free end to the desired distance from the weld.  Not as ideal but will work fine.
Thanks again for all your help!
Message 15 of 26
Here is a little glitch: I ran an ISO with my two pieces of pipe with the "weld" joint... the iso schematic shows and dimensions both pipes but the Bill of Materials combines them as one piece... Hmmmm
At least I'm closer than I was earlier!
Message 16 of 26
dave.wolfe
Did you do a cut list?
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 17 of 26
Not sure how to do a Cut List, but it's correct in the Data Manager... it shows two separate line items for the pipe with correct cut lengths.
Message 18 of 26
TomislavGolubovic
Cut list is in the Iso Styles, when you setup the border and the tables.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 19 of 26
in reply to: TomislavGolubovic
So yes, the Cut Piece List identifies the pipe correctly.  I think I would have to include both the BOM and Cut List on my Isos which is fine... but is there a way to eliminate pipe out of the BOM... that way I don't duplicate material in the list.
Thanks!
Message 20 of 26
Hi Peter,
I've seen you create a flanged pipe.
What is the procedure for this.
I've have try this, I cannot get this to work.
I still have pipe with no flanged.
Here is my procedure.
1.  create new component.
2.  populate size parameters.
3.  save catalog.
4.  add to spec.
Is there anything that I am missing?
Thanks in advance.
”Boost
