AutoCAD Plant 3D General DIscussion
0 Kudos
Post 1 of 9
Flanged Piping Questions .
929 Views, 8 Replies
10-03-2012 01:55 PM
Hello
I am trying to work on Pipe connection settings to allow auto flange but no success.
When I try to connect or rout from a nozzle that is configured as FF (Facing RF ou FF), it doesn't add automatically a flange and the same when I insert a flanged valve or equipment.
I tried to see some forums but doesn't help too much.
Can anybody help, please?
143 Kudos
Post 2 of 9
Re: Flanged Piping Questions .
10-03-2012 07:59 PM in reply to: nawfel.bouzayani
Can you post a screen shot of your compound joint settings?
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
0 Kudos
Post 3 of 9
10-05-2012 08:13 AM in reply to: nawfel.bouzayani
I think that I have a problem in how to configure the Piping Connection Settings in the attached file.
Can any one tell me how shall I configure it to get the autoflanged connection fixed.
Thank you
143 Kudos
Post 4 of 9
10-05-2012 08:20 AM in reply to: nawfel.bouzayani
Sorry, forgot to ask the basic question first...just to make sure we're on the same page.  Are you sure you have FF flanges in your spec?
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
0 Kudos
Post 5 of 9
10-05-2012 09:14 AM in reply to: dave.wolfe
I have FF flanges and facing RF.
0 Kudos
Post 6 of 9
10-09-2012 12:49 PM in reply to: nawfel.bouzayani
This is the spec I am working on.
0 Kudos
Post 7 of 9
10-30-2012 09:14 AM in reply to: dave.wolfe
Does anybody has answer for this problem?
Thank you
Valued Mentor
65 Kudos
Post 8 of 9
10-30-2012 07:13 PM in reply to: nawfel.bouzayani
please try setting your autoflangejoint back to how it came out of the box
then at your flanged joint, modify and remove tick from facing in the required match box.
this will allow you to connect a FF flange to a RF flange, it will give you a warning just pick ok
if you dont want the warning, then delete facing from the required matches completely
i notice you also have created the possibility for a THDM to connect to a THDM and a THDF to a THDF also you have THDM connecting to a FL etc ...are you sure you want these types of connection?
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
0 Kudos
Post 9 of 9
11-01-2013 09:04 AM in reply to: nawfel.bouzayani
Whatever became of this request for help. It appears to have just died without a resolution. The problem that nawfel.bouzayani was having is now the same problem that I'm having in 2014. What was the answer to his problem? No matter what settings I put I keep getting the same results. When autorouting from the end of a pipe a flange is placed with its face attached to the pipe.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
