AutoCAD Plant 3D General DIscussion
dave.wolfe
Message 11 of 24 (404 Views)
Re: Flanged Piping Questions
03-08-2012 12:30 PM in reply to: jpeters
Right, you have to select the pipe first.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
jpeters
Message 12 of 24 (402 Views)
03-08-2012 12:40 PM in reply to: dave.wolfe
Fantastic!  That's what I've been looking for.  Thanks!  Is there a way to move that weld after it's placed?  I don't see any grips on it...
dave.wolfe
Message 13 of 24 (399 Views)
03-08-2012 12:44 PM in reply to: jpeters
You can do a stretch command around the fittings...yea, remember AutoCAD?! :smileyhappy:
Every now and then you can still use those commands.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
jpeters
Message 14 of 24 (391 Views)
03-08-2012 12:58 PM in reply to: dave.wolfe
Ahh, the stretch command...   That works fairly well.  What I was hoping for was a way to select the joint (weld) and move it a specific distance from the other end of the pipe using dynamic input.  Basically setting the cut length of the pipe by moving the weld.  I can do it the other way though... select the pipe and move the free end to the desired distance from the weld.  Not as ideal but will work fine.
Thanks again for all your help!
jpeters
Message 15 of 24 (386 Views)
03-08-2012 01:10 PM in reply to: jpeters
Here is a little glitch: I ran an ISO with my two pieces of pipe with the "weld" joint... the iso schematic shows and dimensions both pipes but the Bill of Materials combines them as one piece... Hmmmm
At least I'm closer than I was earlier!
dave.wolfe
Message 16 of 24 (384 Views)
03-08-2012 01:11 PM in reply to: jpeters
Did you do a cut list?
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
jpeters
Message 17 of 24 (382 Views)
03-08-2012 01:15 PM in reply to: dave.wolfe
Not sure how to do a Cut List, but it's correct in the Data Manager... it shows two separate line items for the pipe with correct cut lengths.
Employee
TomislavGolubovic
Message 18 of 24 (379 Views)
03-08-2012 02:55 PM in reply to: jpeters
Cut list is in the Iso Styles, when you setup the border and the tables.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
jpeters
Message 19 of 24 (368 Views)
03-09-2012 05:56 AM in reply to: TomislavGolubovic
So yes, the Cut Piece List identifies the pipe correctly.  I think I would have to include both the BOM and Cut List on my Isos which is fine... but is there a way to eliminate pipe out of the BOM... that way I don't duplicate material in the list.
Thanks!
MuddyPipe
Message 20 of 24 (281 Views)
06-07-2012 08:49 AM in reply to: dave.wolfe
Hi Peter,
I've seen you create a flanged pipe.
What is the procedure for this.
I've have try this, I cannot get this to work.
I still have pipe with no flanged.
Here is my procedure.
1.  create new component.
2.  populate size parameters.
3.  save catalog.
4.  add to spec.
Is there anything that I am missing?
Thanks in advance.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
