AutoCAD Plant 3D General DIscussion
Member
marodi
Message 1 of 1 (185 Views)
FLANGED PIPE CONNECTION
185 Views, 0 Replies
08-21-2012 05:36 AM
Hello Everyone!
How can you make the following:
I want to put down pipe segments(in a straight line), and I want them to be separated with
flanged connections. I want the flanges to be created automatically(not putting manually,
after the pipe creation). Is it possible?
I tried:
1. Pipe with FL ports, but after that, the software put only on side of the flange, with a gasket,
and a bolt set, and no other side of the flange.
2. Plant3D parametric graphics(v2013)(with flange endings, but this does not seems to look good, when I put them
down, there are empty spaces between the pipe's end and the gasket.
Can anyone write me the proper way of doing this?
Thank You!
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
