AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
FLANGED PIPE CONNECTION
0 REPLIES 0
Message 1 of 1
marodi
368 Views, 0 Replies
Hello Everyone!
How can you make the following:
I want to put down pipe segments(in a straight line), and I want them to be separated with
flanged connections. I want the flanges to be created automatically(not putting manually,
after the pipe creation). Is it possible?
I tried:
1. Pipe with FL ports, but after that, the software put only on side of the flange, with a gasket,
and a bolt set, and no other side of the flange.
2. Plant3D parametric graphics(v2013)(with flange endings, but this does not seems to look good, when I put them
down, there are empty spaces between the pipe's end and the gasket.
Can anyone write me the proper way of doing this?
Thank You!
0 REPLIES 0
”Boost
