AutoCAD Plant 3D Forum
flange inserting wrong gasket
1 REPLY 1
phil.cooper
938 Views, 1 Reply
I have 2 different flanges each with their own gasket and matching short description in the spec.
I have set up the connection so the required match is the short description.
when I insert flange 1, it inserts the correct gasket. but when i insert flange 2, it inserts the gasket for flange 1.
See attached screenshot.
any ideas?
1 REPLY 1
dave.wolfe
in reply to: phil.cooper
I think one way you could fix it is to use a different facing or pressure rating for the second type of flange/gasket.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
