Hello Autodesk,
I fixed an issue and wanted to inform you about it.
I experienced the problem that my object enabler was not working in navisworks simulate on every computer i installed it on. (installation was the full plant 3d 2014 premium suite using the default settings)
I tried reinstalling both the complete software aswell as the object enabler but no luck.
Then i found out that navisworks manage didn't have this problem, everything worked like it is supposed to.
I found out that in the windows register
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Navisworks Simulate x64\11.0\ObjectDBX\R19.1\Applications\
and in the folder
C:\Program Files\Autodesk\Navisworks Simulate 2014\lcdbx2014
the items concerning PnP where missing.
overwriting the folder lcdbx2014 from simulate withe the one from manage and copying the registerkeys from manage to simulate solved my problem.
Is this a fault in the installation of the object enabler?
Corné van Stee
Thank you, Corné. I can confirm this behavior and have logged it to our development department.
Regards
