AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Filler Rings
1 REPLY 1
TRdesigner82
362 Views, 1 Reply
Filler Rings
Does anyone out there have any experience with filler rings? When connecting a raised face metal flange to a plastic flange, filler rings are required so the plastic flange doesn't crack while tightening the bolts. I'm tying to figure out the best way to do this since they're not required on all flange connections. I was thinking maybe a second flange that calls out "W/ FILLER RINGS" or something like that. Also trying to figure out if there's a way to do it with CONNECTORS so that it's more automated. Any thoughts or suggestions would be appreciated....
1 REPLY 1
eadkins73
in reply to: TRdesigner82
We have just went in and manually added the "W/ FILLER RING" to the description in the properties.  But if you wanted to do it automaticall you would probably have to define a new connection type.
Ed Adkins
EA2 Engineering
www.ea2eng.com
”Boost
