May be a wish list here:
The File Name Format affects all the DWGs created in the project. Is there a way to have a different File Name Format for the different types? I have a case where the P&IDs follow one format while the 3D models follow a different format.
Solved by martinTstewart_Adsk. Go to Solution.
Depending on how complicated a drawing number format you have in mind, one way may be to create a Selection List for use in your File name format. If you were to create a Property Name called “Drwg Type” for example, with a selection of one value for P&ID drawings and another for Plant 3D drawings, you can pick between the two each time your create a new drawing. (see attached images)
(If this answers your question, please mark it as an Accepted Solution.)
