AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Fiberglass Pipe
3 REPLIES 3
FishrOfGrizz
468 Views, 3 Replies
Fiberglass Pipe
I'm trying to produce a Fiberglass pipe run that is Spigot on both ends instead of Bell x Spigot because my fittings are all Bell x Bell.
I've tried several configurations of the Size Parameters in the Catalog Editor but the closest that I've come is to remove the Bell. This ends up being a PE  pipe where the Bell was and  the result is that fittings will not make up to that PE.
The other end of the pipe still has the Spgt on it as original and it performs well. You can autoroute off of it with no problem. I'd like to have it produce a Spgt on the other end as well.
Has anyone done this before?
3 REPLIES 3
dave.wolfe
in reply to: FishrOfGrizz
What version of plant are you using?
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
FishrOfGrizz
in reply to: dave.wolfe
2014
Bryan
Bordelon .. Houston, Tx . . (main) 281-920-9559 . . . . (fax)
281-920-3559 . . (email) bryanb@ecl-eng.com
eadkins73
What end types do you have on both ends of your pipe?  PPL?
What end type do you have on your fittings? SW, PSW, MJF, etc.?
Do you have that connection setting set up for this combination?
Ed Adkins
EA2 Engineering
www.ea2eng.com
”Boost
