I'm trying to produce a Fiberglass pipe run that is Spigot on both ends instead of Bell x Spigot because my fittings are all Bell x Bell.
I've tried several configurations of the Size Parameters in the Catalog Editor but the closest that I've come is to remove the Bell. This ends up being a PE pipe where the Bell was and the result is that fittings will not make up to that PE.
The other end of the pipe still has the Spgt on it as original and it performs well. You can autoroute off of it with no problem. I'd like to have it produce a Spgt on the other end as well.
Has anyone done this before?
What version of plant are you using?
What end types do you have on both ends of your pipe? PPL?
What end type do you have on your fittings? SW, PSW, MJF, etc.?
Do you have that connection setting set up for this combination?
