AutoCAD Plant 3D General DIscussion
Valued Mentor
JohnHolder
Message 1 of 5 (644 Views)
FATAL ERROR: *Urgent*
644 Views, 4 Replies
10-15-2012 02:39 PM
FATAL ERROR: Unhandled Access Violation Reading 0xfffffff8 Exception at efdd241ah
Crashes on start up.....
Repaired - no change
Re-installed - no change
When it initially crashed, I renamed the project file I was working and added "bak" to it, in case it was causing the issue.
ACad / revit / ASD all start up without an issue, it is JUST P3D I am currently unable to work.
I put in a ticket, but does anyone have a suggestion aswell?
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
dave.wolfe
Message 2 of 5 (634 Views)
Re: FATAL ERROR: *Urgent*
10-15-2012 04:40 PM in reply to: JohnHolder
Did you clear the graphics cache:
http://www.pdoteam.com/2012/06/fatal-error-on-plant-3d-startup/
and the local data cache:
http://www.pdoteam.com/2012/03/plant-3d-startup-hanging/
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Valued Mentor
JohnHolder
Message 3 of 5 (628 Views)
10-15-2012 04:55 PM in reply to: dave.wolfe
Graphics Cache!
I backed up the directory then deleted everything inside.
Thank you very much Mr. Wolfe!
Master Yoda.
New Member
rick.ramirez
Message 4 of 5 (110 Views)
06-26-2014 09:07 AM in reply to: JohnHolder
Instead of telling people to manually delete these cached files, why doesn't Autodesk resolve the actual problem? Has it even been identified? I have not been given an answer to this question and this problem seems to affect multiple Autodesk products starting with 2013 versions.
If not, is there a setting in Options that can turn off graphics cache? That way when I apply my custom profile, it gets turned off and I don't have to manaully turn it off at each end user workstation.
Product Support
jason.drew
Message 5 of 5 (80 Views)
07-02-2014 04:24 AM in reply to: rick.ramirez
Hi Rick,
The graphics cache can be disabled as a workaround until the issue is fixed by development. The system variables for this are saved in the Windows registry:
CACHEMAXTOTALSIZE (System Variable)
http://help.autodesk.com/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-F3B22467-BC93-4D91-AC10-E93EAB15...
CACHEMAXFILES (System Variable)
http://help.autodesk.com/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-7494F1CE-253B-42AC-BD26-10FB9E8F...
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
