AutoCAD Plant 3D Forum
Exported properties to Navisworks
1 REPLY 1
d.laboulle
1211 Views, 1 Reply
I am exporting  a dwfx file to open it with navisworks.
However when i open the object properties under navisworks, to many properties are displayed and i would like to have only 4 or 5 chosen properties (see attached file Navisworks properties for a pipe.PNG)
I have tried to deal with that with the "dwfoutputsettings3D" but i can't unselect all the properties i don't want to export. (see attached file DWFOUTPUTSETTINGS-2.png)
Then i have been looking in the Projectsetup (see attached file Projectsetup.png), but even when i create a custom import/export setting file, i don't manage to export only the properties i have chosen.
Has any one ever dealt with a similar problem?
Damien
1 REPLY 1
It is currently not possible to adopt the whole properties - either in the export settings nor in Navisworks itself but you can use quick properties to show only those properties which you need. Therefore you have to change the options in Navisworks. See the attached snapshots.
Regards
Bernd
Bernd G.
Senior Product Support Specialist
”Boost
