AutoCAD Plant 3D General DIscussion
Active Contributor
snijdam
Message 1 of 4 (991 Views)
Export from p3d to inventor
991 Views, 3 Replies
09-05-2012 01:55 PM
I know this a strange workflow. Our client has only inventor. I need to make a pipedesign in a factory. I want to use my plant 3d software. After the projec at the client he needs to maintain and edit the model for future purposes. Is it possible to export my plant 3d work to inventor letting my client edit the piping. It is no problem that data and connections were lost. What file format is best?
Employee
TomislavGolubovic
Message 2 of 4 (981 Views)
Re: Export from p3d to inventor
09-05-2012 03:41 PM in reply to: snijdam
You can import a 'dumb' Plant3D model into Inventor. Type EXPORTTOAUTOCAD and create a new 'dumb' DWG file of your Plant model.
As for continued editing, it will be limiting in what they can do, if anything in Inventor with the Plant entities.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Valued Mentor
Rich.O.3d
Message 3 of 4 (977 Views)
09-05-2012 03:58 PM in reply to: snijdam
consider:
doing the piping in Inventor Pro (routed systems)
then dump PCF from inventor and import into Plant3d for creating ISO
not sure if it will fly, but in theory, and from the autodesk advertising blurb, it should be possible
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Product Support
gersteb
Message 4 of 4 (926 Views)
09-14-2012 05:46 AM in reply to: snijdam
Hi snijdam,
Could Tomislav help you? Please, mark it as solved. Otherwise let us know.
Bernd
Bernd Gerstenberger
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
