AutoCAD Plant 3D General DIscussion
tmccar
Message 1 of 6 (283 Views)
Export catalog with unique id
283 Views, 5 Replies
10-08-2012 05:41 AM
I would like to export a catalog (pcat) to Excel with a unique identifier field as one of the columns. Is there any way to achieve this using Spec Editor on Catalog Builder?
dave.wolfe
Message 2 of 6 (281 Views)
Re: Export catalog with unique id
10-08-2012 05:47 AM in reply to: tmccar
The default unique Identifier is the PnPID column which is exported.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
tmccar
Message 3 of 6 (274 Views)
10-08-2012 06:46 AM in reply to: dave.wolfe
It's not unique unfortunately - you can have a part from "Supplier X" and apart from "Supplier Y" with the same PNPid. I would like to be able to distinguish between them.
dave.wolfe
Message 4 of 6 (271 Views)
10-08-2012 07:11 AM in reply to: tmccar
Actually, it is unique for the catalog.  If you have the same PnPID in a spreadsheet in excel, I suspect the last entry will overwrite the first one.  The PnPID is used by the program to know which database row should get updated.
Spoiler
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
tmccar
Message 5 of 6 (208 Views)
10-15-2012 03:14 AM in reply to: dave.wolfe
I would like to have a unique id across all catalogs - what is the best way to achieve this? (I would like to leave the catalogs intact if I can).
dave.wolfe
Message 6 of 6 (201 Views)
10-15-2012 05:13 AM in reply to: tmccar
You can do an export to Excel and then use the Item Code (Part Number) field.  You'll have to fill it in manually for every item (unless you want to use some sort of calculated field).
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
