AutoCAD Plant 3D General DIscussion
HEANRorkraft
Message 1 of 5 (953 Views)
Exclude parts in Report Creator
953 Views, 4 Replies
12-12-2012 04:29 AM
I have a problem with Report Generator that i can't figure out. I am currently in a project where I am connecting to existing pipes. I have modeled these existing pipes but I don't want them in my MTO (of course). I have set the properties for these pipes to "existing" but the still appear in the MTO. The total length of pipes is too much.
How do I exclude pipes and other equipment from the MTO automatically?
Product Support
quentin.contreras
Message 2 of 5 (919 Views)
Re: Exclude parts in Report Creator
12-13-2012 03:08 PM in reply to: HEANRorkraft
First, do you have access to the Report Designer Manual? Please refer to this forum link and the post by Jason Drew, he provides a link to access the manual.
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Report-Creator/td-p/.UMpZaG_Ae_w
The field I used in the Pipe properties was Status. There you can assign the pipe as either New, Existing or Demolition.
Then, I opened Report Creator and I created a new report based off of my existing 3D Parts report. You can either generate a new one or base it off another existing report depending what you are wanting to do. Then I selected Edit and Edit Report layout. I added a new column to include the status.
You will then need to setup a filter. This filter will only place the New items you set in the Status.
Now I will run the default 3D Parts report. Pay notice to the total pipe lengths.
Now the new report that filters Status for New items.
Hopefully, this guides you in the direction you needed.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
HEANRorkraft
Message 3 of 5 (911 Views)
12-13-2012 11:21 PM in reply to: quentin.contreras
Mr. Contreras,
Thank you for a very detailed reply. This is exactly the kind of answers we want when we post questions here!
Regards
Henrik Andersson
Sweden
Active Contributor
evadmoore
Message 4 of 5 (417 Views)
03-19-2014 06:06 AM in reply to: quentin.contreras
I tried to access to the Report Designer Manual?
But it is no longer valid.
Is there a new lick for Reporter 2013 or 2014?
Distinguished Contributor
cadwomen
Message 5 of 5 (412 Views)
03-19-2014 06:19 AM in reply to: evadmoore
re you looking for this ?
Report Designer
 still the same till 2011
cw
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
