Hello
I've installed P3D2014 German last week and migrated the projects. Creating of isometrics was possible.
On Friday I got only errors while creating isometrics. So I opened a new project without template and it is the same?!
What shall I do?
An example of a log is in the attachments, a pic of the piping too...
Guido
Hi Guido,
From the log-file I can see that several iso symbols weren't found. Those symbols are located in the IsoSymbolStyles.dwg. A new project will be created on the base of the default project which is located here: C:\Program Files\Autodesk\AutoCAD 2014\PLNT3D\UserDataCache\en-us\DefaultProject or in your case:
C:\Programme\Autodesk\AutoCAD 2014\PLNT3D\UserDataCache\de-de\DefaultProject. So it seems that your IsoSymbolStyles.dwg was corrupted. A reinstall replaced this file and solved your issue.
Regards
Bernd
