Hi to everyone again...
Today..my problem is a error when I route a new line of pipe
1.- In the Spec I changed some ND.
2.- When I start a Route piepe an error occurs "Can not find a reducer of required size in the current spec"
(I show you a .jpg)
3.- I clean from the spec reducer and the problem is still on for all ND of my spec.
4.- anyone knows where the problem comes?
Thanks..
Hi to everyone...
I solved the problem written above.
1.- When occurs the error: "Can not find a reducer of required size in the current spec"
I detected that Pipe Spec (only Pipe Component) is corrupted, I don´t know why, but I think it was because I made some several changes in all ND for each one.
2.- So, my solution was Delete Pipe component from catalog, and create a new one Pipe Component, and all works good.
Remember only delete Pipe Component from catalog, everything else will continue to operate well as elbows, reducers, flanges, etc...
I hope to serve you if you find this problem.
Thanks.
