I have two 90 deg 2.5" Ells in a drawing. Other fittings, pipe and equipment do not cause this error. When these two are deleted it saves properly.
When I save the drawing I get
An unknown error has occured.
Please include the details below when you report this issue to your administrator or Autodesk.
PnPCompletionStatus.FailedToAcceptChanged
Abort due to constraint violation
PRIMARY KEY must be unique
when I delete the two ells it saves as normal.
any ideas?
John.
Edit - I swapped the 90 deg Ells for 2 - 45 deg Ells. it saves, but the issue is still there.
I had only encounter errors like that when i create cutom definecalculated properties and delete them. Have you created and deleted any plantdefinedcalculated property? thanks
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
As soon as you deleted them, have you tried to close out of all open drawing an run the PLANTAUDIT?
If that does not help then, backup the drawing first and use Open command to open the drawing like a normal AutoCAD drawing file. Then run and AUDIT of the drawing.
See if that helps to resolve the issue you are having.
Quentin Contreras
Technical Support Specialist
Not sure what happened..
I saved two copies. one with no ells ( no 90 or 45's ) and the other I replaced the 90's with 45's. - ran <audit project> from the project manager.
did my orthos as needed
removed them from the project.
I put them back into the project to test as you suggested but they worked this time.
sooo not sure what happened.
Plant 3D gremlins I guess!
Glad you are up and running though!
Quentin Contreras
