I got this error message when I was creating an ISO. After I got this error message, I can´t make any ISO´s in any projects. I could not figure out how to fix this, so I formatted my computer to erease all datas. Then I reinsatalled windows and Plant 3D. Then I could make ISO´s again, and it worked just fine, until I was going to create an ISO on the same linenumber that created the ISO error the first time (see image). The only thing I have done with this particular linenumber, is that I added some ISO messages. I guess that this is an windows issue, but I post this problem to hear if anyone else has experieced this...
Any suggestions??
PS!! I´m running Bootcamp on a macbook pro...
If you reassign the line number to the pipe model are you able to create an Iso? Also, what happens if you try creating a Quick Iso?
Dan
Hello Dan.
I can´t create any ISO´s after I got the error message. Even not quick ISO´s, and not in any projects. The errormessage shows up everytime I try to create ISO´s, and Plant 3D crashes.
