I found an error when I try to open the title block to edit my iso style. In the attached file follow an image of the error. Even when I hit on continue nothing happens.
I'm using AutoCad Plant 3D 2013 and the project files are located in the SQL Server Express 2008.
Someone could clarify what's going on and how can I fix it?
Thanks in advance!
Fernando
That is interesting:
Invalid ND format: 1 1/2 mm.
It is look like that there is a mixup betveen the inch and mm units.
Bat what does it have to do with the title block?
I don't know.
There is another detail about this problem, it happens only in my actual project. I took the isometrics files and put them in a previous project and the title block settings worked as expect, without errors.
Obviously I could make any changes in the title block using my previous project and transfer the files to my present project, but I wouldn't like to do this. This will be my last option.
So I am still waiting for a solution for this weird error.
Thanks.
Fernando
Has someone faced this same issue with title block editor?
I need to add some attributes on my iso title block and with this error I can't.
Any help would be great.
Fernando
Hi Guys,
I'm working on a mixed unit Project, and currently I'm having the same issue...
I'm using Plant3D 2014. Any ideas how can I fix it?
Cheers,
MD
Good day. Maybe you can try this for checking, just maybe.
1. Create new project, copy your settings. Edit the Title block in that new project and see if same error occurs. (if you can edit your title block the problem is within the project files, maybe spec or catalog used)
2. Next, as per the notification error, maybe your problem is on the Spec components. I havent encountered this since my 1st use of Plant 3D, delete or cut your existing specs on the project and add the default Plant 3D spec (EG. CS300). Try to edit title block if it will allow you.
3. Audit and Compress your project and use Pnplocaldatacachepurger and see if the problem solved.
Hope this would help, many thanks.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
