AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ERROR IN P&ID
2 REPLIES 2
1034 Views, 2 Replies
ERROR IN P&ID
hi am working in p & id but not assign me let me tag and generates an error
another schematic line group in the project has the same tag which has not been saved
cannot merge with that group
please make sure group tag is unique
2 REPLIES 2
michael_downham
I am also having this issue.  Have you found a solution yet?
I found a solution to this problem.  You need to close all drawings and then close the Project.  Open the project back up.  Right on the project name and select "Audit Project".  This should clear out the items in the Database that are not referenced in the drawings.
”Boost
