AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ERROR in Catalog Builder - Creating block based part
5 REPLIES 5
agutak
1062 Views, 5 Replies
I want to create my custom Tee catalog
1) I draw a tee in Inventor 2013
2) Export it as *.adsk (also I've tried as *.dwg)
3) Import it in Plant3D 2013, convert to Block, convert with PLANTPARTCONVERT and save this file.
Then when I'm trying to open it in Catalog Builder I have: "Invalid Dwg file :eNotAllowedForThisProxy". What is wrong?
Please, help me to finish my job!
Anatol D. Gutak
5 REPLIES 5
Venkatesan.A
in reply to: agutak
eNotAllowedForThisProxy exception error means that the drawing contains some hidden Proxy objects, can you purge the dwg and try again?
Venkatesan.A
Support Specialist
Product Support
fedorafly
in reply to: agutak
Mark for learning.
agutak
in reply to: agutak
I've tried all this but it doesn't work.
I found a solution for this problem. I export my inventor assembly as *.sat, then import it in Plant3D and then convert to block and plantpartconvert.
In this way I can import my created *.dwg in Catalog Builder
Anatol D. Gutak
Rich.O.3d
in reply to: agutak
my method:
from your part in inventor
hit save as...Save Copy As
select autocad dwg file from the file type pull down
select options....detick all but solids
this will give you a nice autocad object, open the dwg, purge all, and move the solid to have the wcs origin where you want it.
for catalogs i then put all of one type (such as equal tees) in the one file (keep them as blocks)
this makes it much easier to manage and select from the cat builder.
ps you dont need to remodel everything, i pull most of my stuff from the content centre
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
in reply to: agutak
same problem i face. i am make one of model in plant 3d and make block then used plantpartconvert command and set the ip point (as per plant3d vedio shown) and when go to catlogeditor set all point. and save part not to config with part.png file.
”Boost
